I have the same problem on where the bumper joins the front left quater panel. The car was hit from that side and i guess they never repared it properly.
If you get it fixed can you let me know how you did it if it was a DIY job.
Hey guys long time no speak
Just starting to tidy up the motor for our annual show comming up?anyway i shaved my tow hook cover and got it all sprayed up and mint, however the bumper sags a little anyone had this and sorted them out?
prob means a clip has snapped and ill need a new one but maybe i can DIY something to make it heaps tighter all round
cheers tom
MK1 GLS 3door
A4 B7 2.0T
yer I will DIT most likely ill let you know
I think my front bumper has got the same issue, taken a hit and broken the brackets, might see if i can source some more at some stage.
1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
Yes, this seems to be a very common prob
my car has the same ,
I have had a a bit of success by adjusting the bolts that hold the bumper to the crumple rail as they seem to loose tension.
I would think that the bumper & its mounting system are part of the crumple zone
I think it is caused by parking mishaps, when another car just pushes against the bumper & bends the bracket slightly
You can slip a washer or some other form of spacer between the bracket & inside of the rail, but you are limited by the lenght of the bolt to how much you can gain back
& you get access to do this by removing the blinker
