Ryans Mk2 is a factory 2L from South Africa. 2E engine.
It is excellent, reliable as a daily and fast enough as a hot hatch.
How is the seat repair treating you Ryan?
was the drive back to wagga fun?
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
Hey Ryan, regarding the mk3 sd7v16 swap, what else was needed from the mk3 other than the compressor?
Sent from my iPhone using Tapatalk - now Free
Got Turbo Inside
Seat's awesome, I can drive long distance now without destroying my back.
The trip back was great, love the PS the most, give's the car a really quick 'turn in' feel to it.
It's not the easiest job, CamdenGTI had a few things modified to work for me.
This page explains it, VWVortex.com - MK2 ABA Serpentine Conversion Including A/C and P/S.
AFAI, you'll need
-Complete MK3 (GL) belt setup (AC comp, Alt, brackets, PS pump, pulleys)
-Corrado radiator (correct hoses)
-You could use a raddo G60 compressor to keep the same hose fittings
-Or have the A/C hoses modified to accept the SD7V16 out lets
-Time/patience
HAHAHA
Will look good with wheels and some lows. You have coilovers?
Thanks for sharing how you did it.
My situation is slightly different, I have the SD7V16 compressor but figuring how to connect with existing mk2 hoses. I don't mind using the old v belt setup just want to swap out the old sd508. I assume the mk3 hoses will not fit on mk2, looks like I need to get someone to modify the fitting
Got Turbo Inside
Good choice for the wheels, have been considering a set of those myself. Looking forward to see pictures of them fitted.![]()
Nice work man looking good![]()
Quick update, think I finally sorted out fitment.
Ended up going with Zetum 195/50's (if you want to run low, go with 45's.... or 7 inch rims lol)
Some pics as it sits currently,
Front's are running 1.75degrees camber and almost never scrub
Rear's may need raising, for that cheeky Jack-russell look...
And one from DOVW, (note the out of date rego sticker..... police don't like that)
HAHAHA
