Page 25 of 30 FirstFirst ... 152324252627 ... LastLast
Results 241 to 250 of 299
Thread: Ryans MK2 GTI
  1. #241
    May 2010
    NQ
    Quote Originally Posted by Bamish1000 View Post
    I have a new set of Black indicators and a new set of crystal clears....let me know if you want pics?
    Daammit!
    Just bought a pair from Germany.
    They're on a slow boat to Australia
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
  2. #242
    May 2010
    NQ
    Spent today replacing the water pump/parts and some breather seals (1.8 folk, take no notice).
    Also, thank-you to whoever did this,
    Hope you all had a good new years
    HAHAHA
  3. #243
    bardon
    Ours was exactly the same and we too tried a torx but that didnt work either. We ground down each side with a dremel and put a spanner over it and cracked it off, I think we added a little heat as well.. Thats why no mechanics want to touch our cars!!
    The 16V ABF required us to remove the whole front end!
    Good luck!
    And.. Im sure we replaced all three with Stainless new ones!
  4. #244
    May 2010
    NQ
    Finished off another few things with the help of GAP.
    New gearstick boot (about time)
    Replaced the main water flange on the head (it started leaking, for no reason?) aswell as my first attempt to 'hide' the overflow hose...
    Got a 22mm master cylinder itching to go in aswell
    Also, the reinforced chain rubber exhaust hangers from gap are awesome.
    HAHAHA
  5. #245
    Dec 2008
    Bentleigh, Melbourne
    Why the F^%# is your engine bay so clean!!!!!!!
    haha, good job ryan
  6. #246
    Nice work on the overflow hose, what's going on with your intake hose? Seems quiet offset?
    8v Ibiza GTI > 8v mk2 Golf GTI > mk3 VR6 > 8v Ibiza GTI > 2D CL+vr6...
  7. #247
    May 2010
    NQ
    Quote Originally Posted by Stiggy_21 View Post
    haha, good job ryan
    Because the rest of the car isn't haha.
    Quote Originally Posted by hamza View Post
    The 2E engine + intake manifold sit higher than the regular 1.8's.
    Whover built the car must've got that boot (with the offset design) and used it.
    Parts bin special haha.
    HAHAHA
  8. #248
    May 2010
    NQ
    22mm master cylinder is in, big improvement, the pedal is actually hard!
    Still need to do a bit more bleeding.
    This is why you should reguarly change brake fluid,
    The black soot in the red container was all from the old master and the fluid in the jar should be clear yellow.
    HAHAHA
  9. #249
    Apr 2008
    Nice one
    So where'd you get the 22m MS from? Can I ask what stock is?
    I've got MK3 hubs/calipers to go on, thought I might do it all at once.
  10. #250
    May 2010
    NQ
    Quote Originally Posted by benough View Post
    Nice one
    Got mine from GAP, or just ask an auto store for a 22mm MK3 GL, non ABS, MS.
    Standard is 20mm (2 Brake ports in my case), 22mm uses 4 ports but I just blocked 2 off with bleed nipples.
    If I can find a MK3 GL being wrecked nearby, I'd like to swap the brake set-up over too.
    HAHAHA
