Page 17 of 30 FirstFirst ... 7151617181927 ... LastLast
Results 161 to 170 of 299
Thread: Ryans MK2 GTI
  1. #161
    May 2010
    NQ
    Quote Originally Posted by Stiggy_21 View Post
    I just replaced my ignition lock housing. To get the spline adapter off, I put some vice grips behind the shoulder of the adapter. Then attach some gear pullers onto them and the steering column. It came off quite easily.
    Ryan that link u put up is great!!
    My bearing was a little sloppy, but the ignition switch was f*#%*$!!! it starts easily now
    Took less than an hour
    Nawww, I must just be unlucky then haha.
    I tried a similar method to above (with a bearing puller) but just ended up mangling the shoulder.
    My ignition switch is starting to get tempremental.
    Gonna try it again soon with a bearing separator.... fingers crossed.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
  2. #162
    Apr 2010
    City of Swan, WA
    Quote Originally Posted by Lilquakes View Post
    looks mad! really does suite the car man!
    Nice! Can you share whats the model and make? Does it have Aux input for ipods?
    Got Turbo Inside
  3. #163
    May 2010
    NQ
    Quote Originally Posted by rutti View Post
    I can do 1 better
    In-Dash MP3 Player with Radio - Jaycar Electronics
    USB, SD, AUX input's
    (no CD player, but who still uses CD's?)
    HAHAHA
  4. #164
    Dec 2008
    Bentleigh, Melbourne
    Quote Originally Posted by ryana89 View Post
    Awesome radio!!
    I had the same problem, dont directly put the puller onto the shoulder.
    Clamp a pair of vice grips onto the adapter (behind the shoulder) use the back of the grips as your surface to pull against, if not try some wd40 too
  5. #165
    Dec 2008
    May 2010
    NQ
    Awesome radio!!
    I attempted it that way, albeit with locking pliers (all I had at the time).
    The photo you got there is the exact way I'll be doing it.
    I already have the bearing seperator shown in that picture, all I need is the pulling tool, which I hope to pick up from work when then come in
    Fun, fun, fun
    HAHAHA
  7. #167
    May 2010
    NQ
    Well Stiggy, it required ALOT of force to pull mine off haha, but it did come off
    This was my set-up,
    (can you see the the very stupid mistake I made in the above piture?)
    You were right though, I had play in the lock housing bearing and the ignition switch was FUBAR'd.
    Much more solid to drive now and easy as starting!
    HAHAHA
  8. #168
    Apr 2008
    Hey Ryan
    Can I ask about the gauge panel you have down under the ashtray?
  9. #169
    May 2010
    NQ
    Quote Originally Posted by benough View Post
    Hey Ryan
    Shoot away
    HAHAHA
  10. #170
    Dec 2008
    This was my set-up,
    the nuts backwards?? either way you got it off!!!
    much better now ay
