Page 6 of 30 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 299
Thread: Ryans MK2 GTI
  1. #51
    May 2010
    NQ
    Quote Originally Posted by RhysQ View Post
    Adams old car! Looking good mate, nice to see you're keeping it nice and clean.
    Certainly is and I plan on keeping it that way
    Quote Originally Posted by DangerDan View Post
    Looking good
    As always
  2. #52
    May 2010
    NQ
    Hit the rust with a rust converter (from Bunnings ) and let that dry over night.
    Next up I gave it 3 prime coats with kill rust (in a tin), which turned out quite well.
    Finally (paint wise), just used a old tin of touch up paint from our old Falcon, (wasn't even sure how close the colour was) gave it 5 light coats and the result was this.
    Of course I sprayed as much fish oil as possible inside the tunnel to hopefully slow any further rust (god forbid it come back!)
    Then just put some "Knead it" to fill the hole and give it a bit of water resistance.
    This hopfully won't be permanent, just until I can afford to get new metal welded in there properly.
  3. #53
    Jun 2007
    Eastern Suburbs Melbourne
    better than leaving it there to get even rustier!
    good stuff
    i like volkswagens
  4. #54
    Aug 2006
    Melbourne VIC
    Looks like a good short term fix to me!
  5. #55
    May 2010
    NQ
    We'll today I did the Upgrade that Ive been planning on doing for a while....upgrading my headlights!!!
    As any MK2 owner would know how craap their headlights are, I followed the step by step thread posted by velly_16v_cab in the 'Conversion' area of the forum
    Now I actaully have decent low beam!!!
    Lowbeam/Dip Before and After
    And the High beam Before and After (Not as noticable result)
    Planning of getting some Philips Extreme +80 Globes once I have the $$.
  6. #56
    May 2010
    NQ
    Was going to do a bit of work to the car on Saturday.
    Planned on :
    -Changing tranny drive flange seals
    -Replacing Gearbox oil
    -Replacing leaking oil cooler pipe (cooland leak)
    -Fixing oil cooler flange leak
    -Addressing a split steering rack boot.
    However, we only had our friends hoist for about 5 hours in which time we only managed to do the first 2 things on the list!!!
    We also managed to forget to put the new cap/seal on the drive flange back on (of course this was realised AFTER resassembling the front drive assembly)
    DOH!!!
    So the car will be going back there soon to put that seal in and hopfully do a few of the other things that where planned
  7. #57
    Apr 2008
    Quote Originally Posted by ryana89 View Post
    Can I be nit picky and ask if the camera had the same settings kept for each photo?
    Thanks
  8. #58
    May 2010
    NQ
    Quote Originally Posted by benough View Post
    Thanks
    Certainly did, didn't change a thing.
    The car was also in a similar position both times aswell.
  9. #59
    May 2010
    NQ
    I feel like my car is trying to get revenge on me for no reason at all.
    Had to get the muffler replaced today as the original was well an truly buggered.
    So $140 (not a bad price) later, I now have a much healthier sounding exhaust note, aswell as having the exhaust tips sitting in a much better position.
    The synthetic gearbox oil has now givin me a much much much better gear change feel, it really 'slips' into gear by itself now with no effort.
    Incase your interested the oil is called 'Super Shift LS' and is made by a company called 'Marque Lubricants'. Its an API 75W90 GL-5 rated oil. We have it in both our manual cars and many friends use the stuff aswell. A very good oil IMO.
  10. #60
    Feb 2007
    Im guna note that down. I have read on Vortex that the best oil you can use in a 5speed is the stuff they put in the corvette gearbox.
    MK1 GLS 3door
    A4 B7 2.0T
