Results 31 to 36 of 36
Thread: Rutti's Golf MK2 GTI-(RR)
  1. #31
    May 2010
    NQ
    Looks great! Function over form any day.
    Is that your welding?
    You could take it for a test drive with no grille.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
  2. #32
    Apr 2010
    City of Swan, WA
    I wish I have a welder and know how to! Nah, bought the surge tank from fleabay
    Quote Originally Posted by ryana89 View Post
    ---------- Post added 27-11-2011 at 08:57 PM ---------- Previous post was 24-11-2011 at 07:48 AM ----------
    Does anyone know which rpm should i be referring when setting ignition timing, idle speed? I have been doing it with the MFA screen but realised the rpm meter is lower by about 100-150 rpm. I am wondering if this is the reason the car stalls/splutters when warm.
    I have replaced and done the following:
    Replaced CTS
    Cleaned ISV
    Checked throttle switches
    checked ECU grounding (0.2 ohms)
    Replaced all vacuum hoses
    When i pull out the CTS, you can hear timing change and does not splutter
    Got Turbo Inside
  3. #33
    Apr 2010
    City of Swan, WA
    Found the problem. Its a dead o2 sensor! Was tricky because everytime i pulled out the CTS, it bypasses the o2 sensor so it always runs fine.
    Bleed the brakes and went for a drive.... no more stalling at traffic lights! Idles slightly rough maybe because of my 272 cam but only fluctuates between 800-850rpm. Finally, its reliable to drive since i bought it 5 months ago.
    Quote Originally Posted by rutti View Post
    Replaced CTS
    Cleaned ISV
    Got Turbo Inside
  4. #34
    Apr 2010
    City of Swan, WA
    I'm back from a long hiatus... have been enjoying driving until recently when more work was done to 'Gunter'.
    With more free time now, i thought i should restart this again.
    Found these underneath the carpet while fiddling with gear stick... got some freebies and cashback from previous owner.
    Rutti's Golf MK2 GTI-(RR)-img_0402-jpgRutti's Golf MK2 GTI-(RR)-img_0404-jpg
    Got Turbo Inside
  5. #35
    Apr 2010
    City of Swan, WA
    Have been feeling too much engine rocking and occasional 'thud' on firewall, eventually found the rear engine mount is shot!
    Decided to go cheap (instead of using poly mounts) to make a stiffer OEM rear mount by inserting some rubber strips into the gaps... not sure if it will help.
    Transmission and front mounts were also replaced at the same time.
    Rutti's Golf MK2 GTI-(RR)-img_0349-jpgRutti's Golf MK2 GTI-(RR)-img_0203-jpgRutti's Golf MK2 GTI-(RR)-img_0205-jpg
    Got Turbo Inside
  6. #36
    Also a on the cheap fix is to fill the gaps with silicone or sikaflex (i think) you can buy it at any auto parts store.
    8v Ibiza GTI > 8v mk2 Golf GTI > mk3 VR6 > 8v Ibiza GTI > 2D CL+vr6...
