Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: For Robin, so he takes the plunge...
  1. #41
    Golfwise Guest
    GOOD MORNING PEOPLE.IT'S A NEW DAWN
  2. #42
    Surrey, UK
    Glad we are having this converstaion, Roscoe. I feel that mine always locks the rear brakes in the same way. Do you think it is worth adjusting the rear bias a little? I also find that the car wallows a little too much and is less neutral than it has been due to a diff locker being installed. It does help a bit with less understeer when pushed hard, but when cruising it has more understeer. Do you reckon a stiffer rear sway will help this?[/quote]
    The rear bias will only help to a point, the problem is that the wheels are loosing grip because there is no weight on them, a softer rebound setting or stiffer front springs would be the way to go. I am not sure of the effect of a rear anti roll bar on a Golf specifically but eliminating roll will help with traction by keeping the inside front wheel on the ground while cornering. Softer rebound settings can also help but it is usually a balancing act between handling and grip. A locked diff will of course mean that grip is less of a problem.
  3. #43
    Canberra
    To those people that dont like RS (Tim), you dont get it, and therefore should never own any. They are the best wheels on the planet for a Mk2, and Simmons by comparison are not that great. BBS are engineered so much nicer... End of Story. Tim, my rs are 3 piece, not 1 piece...
    Euro look 2... Mk2 love!
  4. #44
    sydney
    the rs is in da house!!!! soon to have a bit of mick jagger disease maybe even with some gold teath
  5. #45
    Aug 2005
    Prahran, Vic
    ahhh so ur the person that bought those. they were the ones on ebay for ages yeh? i was contemplating buying those. they were bloody cheap thou ey. they need a bit of work, and adapters, but will still work out cheap id imagine.
