Results 1 to 10 of 13
Thread: reversing lights have stopped working
    Aug 2005
    Prahran, Vic
    hey all,
    the reversing lights on my mk2 have stopped working. the bulbs and fuse are all good. i recently got a stereo installed by tower audio (known for their high quality installs). so im thinking maybe they knocked a wire off without knowing it or the sub has vibrated something loose. ive had a look but havn't seen anything suspicious.
    anyone got any ideas?
    syncro Guest
    Check the switch on the gearbox by joining the two wires together. These switches are a known problem.
    Aug 2005
    Prahran, Vic
    ah cool. ahh, how can i get at the switch??? from the engine bay, cabin or..?
    cheers cob
    syncro Guest
    On the gearbox.
    Camden, Sydney
    If its not that, it could be an earth in the boot. Probably not if your other lights work.
    Feb 2006
    Perth Western Australia
    reverse lights
    if you look at your gearbox under the brake booster you will see a llarge approx 1 inch fitting screwing into your gearbox with two wires attached. If you turn on the ignition and touch the two wires together it should turn on your reverse lights. If they don't turn on you can be sure that you either have no earth, no power or busted globes. If the lights do come on then the reverse switch in the box is shot (the reverse switch is actually the fitting which you pulled the wire off)
    luke
    77 Golf tarmac rally
    89 porsche 911
    80 Rabbit 4dr
    11 mk1 and 2\'s in various states of undress
    KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
    Aug 2005
    Prahran, Vic
    ah thanks for that volks, ill check it out on the weekend when this laziness wears off.
    Aug 2005
    Prahran, Vic
    yep the old switch is megangled. anyone know where i could get a new one? spose ill give repco a try first.
    is there anything i need to be aware of when i take out the old switch? hot oil isnt gona spray out everywhere or anything...? im still learning..
    Camden, Sydney
    Its pretty foolproof. No oil should come out, expecialy if you do it when the car is cold. I have secondhand ones if you cant get a newy.
    Oct 2005
    Nowra, NSW
    My switch was gone, Wayne penrose tried to track one down for me when i bought the car from him. He had to get one from Vw and it was $150! ouch lucky i didnt pay for it
Similar Threads
  1. Help - Brake lights dont work!
    By XXX-1.8T in forum Mk1 Golf
    Last Post: 24-09-2006, 12:11 AM
  2. Trip computer and internal light stopped working
    By Red Mk1 in forum Mk2 Golf & Jetta
    Last Post: 05-12-2005, 11:41 AM
  3. Head lights dull
    By SPC in forum Mk1 Golf
    Last Post: 24-07-2005, 10:21 AM
