Results 1 to 3 of 3
Thread: Reverse lights weird problem
    Oct 2010
    Not sure if this is the right place to post this but I'm having a weird problem with my reverse lights. I splice a mk2 connector to the mk4 agu harness and when I put the car in reverse the car kicks over. Everything else on the car works except for this weird problem. Any help is appreciated
    91' Golf mk2 GTi 1.8t (soon to be gtx3076’d)
    Golf mk2 GTi 8v
    02' Audi S3 (soon to be gtx3076’d)
    Mar 2013
    Brisbane QLD
    by kicking over do you mean the car cranks when you physically put the shift lever in the car into reverse? if yes i have seen this before.. after a repair the linkage on top of the gearbox was refitted but the big balance weight was put in the incorrect position so when reverse was selected the balance weight actually moved over and hit the stater motor power connection... this waz a mk5 but similar set up...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Oct 2010
    Quote Originally Posted by vdubmotorworx View Post
    Thanks for your reply. I ended up finding out that a pin from the f plug had been put in the wrong place, swapped it over and now everything is working.
    Golf mk2 GTi 8v
