by kicking over do you mean the car cranks when you physically put the shift lever in the car into reverse? if yes i have seen this before.. after a repair the linkage on top of the gearbox was refitted but the big balance weight was put in the incorrect position so when reverse was selected the balance weight actually moved over and hit the stater motor power connection... this waz a mk5 but similar set up...VDUB...
