Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Replacing the Head Gasket - Any pointers?
    Apr 2008
    As the diagnosis continues, a top up of the oil revealed the "milky white paste of death"
    Quite certain the head gasket needs replacing. It would explain why I am slowing losing coolant even though a pressure test showed no leaks.
    Also it has been burning oil and heating up since my brother had it from thursday which also adds to the head gasket being the culprit
    So can anyone offer any advice when replacing it?
    Gonna be going off the Bentley Manual.
    Jun 2006
    Orange NSW
    Take it to a good mechanic, let them do it.
    Its not an easy job, and you need the gear and know how to do it.
    This is the BEST and CHEAPEST alternative if you don't want to pull the head off.
    http://www.rxauto.com/
    I have used it in my ex-Mk2 with great success. There are similar products in Repco and Superchip auto in $10 a bottle but I didn't trust them.
    More story => http://forums.vwvortex.com/zerothread?id=2464602
    Oakleigh VIC
    In my experience the head gasket is usually just the victim of some other root cause.
    Be prepared that there may need to be some headwork done. Head gaskets are pretty tough things and don't usually spontaneously fail due to old age. Corrosion can be an issue though if the right coolants aren't being used.
    Make sure you get the head checked out by an expert and preferably pressure tested.
    Hopefully the new gasket will sort it out. Remember that you'll need new head bolts too, they're stretch bolts and can only be used once.
    Pete
    Pete
    That's correct, in my case. The HG was gone due to radiator burst and I kept driving for 5 minutes with coolant The sealant solution worked perfectly for me.
    Apr 2008
    I have replaced the radiator and a hose b/c the tank had a huge crack in it.
    So before that it was driven short distances and topped up. Not the best.
    I think it was changed a bit late in the game
    Yeah Pete I am getting the head shaved. Also I have got all the new bolts and gasket(s) as well.
    First of all I am gonna get it off and have a look see. The original radiator lasted a long time so I think the coolant was good and have been using good stuff ever since. Hoping corrosion won't be an issue.
    It hasn't been blowing smoke, even since the gasket had gone so I am guessing we won't need to do the valves.
    Aug 2007
    Cylinder leakage test will show this fault for sure mate if done right and if found like Peter says there wil most likely be pits in the head, hopefully not too deep and can be shaved
    JMac
    Alba European
    Aug 2005
    It's perfectly 'DIY-able'. Just have the head shaved - might aswell get them to replace valve stem seals and even guides whilst it's off, then flat the block surface with a large sanding block and some wet 'n' dry or even scotch brite pads on a 90deg angled die grinder (better for a cast iron block than than the sand paper, which is better for alloy in my opinion).
    Just make sure it's all clean and flat and you cannot possibly go wrong
    Also clean all the head bolt threads in the block with compressed air and a clean tap otherwise any engine oil left in them may be forced up and affect the sealing of the gasket. ARP head studs and nuts make the head easier to fit back up as well.
    Oh, and use a good torque wrench when you tighten it back down (after having removed the head bolts in the correct order of course).
    Apr 2008
    Well I took the plunge and got the head off aaaand it's not looking good...
    Is the head ruined? The holes where the coolant runs through are all rusted and they all look much bigger than than the holes on my new gasket do.
    Same with the block.
    So what do people think my options are?
    Camden, Sydney
    Block may clean up. Head is gonna need some welding and resurfacing, or replacing with another.
    Take the headgasket off, clean out the bores and put a bolt back in each bolt hole to clean them out and then clean up the surface of the block.
    Show us a pic of that and we`ll give you a verdict.
    I can help with a cheap replacement head or a full motor at budget prices. Let me know if you need the hook up.
