Results 1 to 7 of 7
Thread: Replacing Blue Coolant Temp Sensor Mk2 Golf GTI 8v
Threaded View
  1. #2
    May 2010
    NQ
    Evening, you're on the right track.
    Your MK2 has 2 coolant temp sensors,
    1 is BLACK and tells the gauge in your dash what to do (these fail and cause weird/no needle movement)
    1 is BLUE and tells the ECU info about coolant temp (these are a common failure too and cause weird running)
    Pull the retaining clip off, old out new in, and make sure the rubber o-ring is there.
    And follow whatever method it says for the 3000rpm business.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
