Ok
It's all back in.
Got a heater hose off Brian but he told me you can get the feed hose locally. Found some old heater hose in the garage and it fit nicely.
Other than the temp control cable clip not holding properly it all works. The heater is brilliant, gives out heat super early unlike my MK5.
Only think not working is the MFA switch. I checked it with an older stalk and it won't switch it either. It must be a wire loose or the cluster has an issue. Hope not!
