just a large socket should fit...thats how i did mine back in the uk
It looks like a normal bolt but my ratchet didn't fit in there.
Do you need a special tool or a trick to do it?
Last time I payed a guy to do it but it looks super easy.
Yeah I just need to know how to get a socket in there...
You will just need a large socket like velly said, with an extension bar on it so you can get it in and turn.
Ben a 6" extension should do the trick. Make sure you either have a handy helper or just put on the steering lock. Also leave the bolt on by a few threads when tugging off the wheel to stop it hitting you when it lets go...
73 mini clubman supercharged money pit
Cheers for the tips.
My biggest socket is a 19mm. It looked bigger than that...
I have used a 24mm deepwell socket with as the other's have indicated a 6 inch extension. A standard socket may also fit. I just checked a spare wheel I have in my workshop, and the 24mm fits nice.
Have fun
Peter
Grumman Kubvan, 1.6L TD
Exploring the Salish Sea
The 24mm worked a treat.
Forgot to mark the steering wheel postion with a texta so I had to adjust it 3 times before it would drive straight, haha!
Thanks everyone. It's so nice to be able to indicate to the right again
