Results 1 to 7 of 7
Thread: Removing coilovers and installing Springs
    Jul 2013
    Hey all. So what am I going to need to install the new springs after removing the coilovers. Do I need a spring compressor?? Thanks
    Aug 2006
    Melbourne VIC
    Have you fitted the springs to your Koni shocks? You will need a spring compressor for the fronts, rear you shoule be able to do by hand.
    Did you pick them up from Seb ok?
    Jul 2013
    Sweet man. Yeah picked up, all good. So you install the spring to the strut before installing.
    Jul 2013
    Here's a guide for the rears that I found
    http://www.vaglinks.com/Docs/VW/MKII...eplacement.pdf
    Jul 2013
    Thats awesome mate. Thanks. Looks pretty simple. Really pumped to get the new Koni shocks and lowered springs in. Should ride much better on the rough roads that I drive on everyday.....
    Sep 2011
    New South Wales
    How did you go with the spring compressing? Did you need to compress the rears? It is recommended that you compress it, but I was just wondering what you did
    May 2012
    i got away with no spring compressor on my mk3.
    what ended up happening to your coils?
