Results 1 to 2 of 2
Thread: removal of c arm tips
    Jun 2006
    Hornsby
    I want to replace my bushings but I have hear so many horror stories with the captive nut failing I am nervous hahah.
    I cant get the front pivot bolts out even with a breaker bar... not a good start.
    90 GTI Mk2 1.8t soon to be with GT28rs
    Dec 2007
    Perth, WA. *YAWN*...
    Undo the nut (19mm iirc) but leave it on the end to protect the thread in case you miss with the hammer.
    Then get a breaker bar or something similar and wedge it between the hub housing & control arm and pull down hard to help them seperate.
    Then, get a solid sized hammer and belt the hub eye casting around the pivot bolt. A few good blows should shock it loose. Dont be a sissy, you gotta hit it!
    Hope that helps dude.
