Hi there Alkl,
I a,m hoping that someone may be able to shed some insight to a very frustrating problem that I have had on a number of occasions.
recently acquired a very nice mk2 with 2.0 conversion and drove from Melbourne to qld no worries.
3 times now it has just stopped at various cruising speeds as if no spark, triple checked all wiring and only recently made this discovery
The car refuses to start when exhibiting this issue, there is spark but only weak spark..
When checking all wiring everything checks out (signal to ecu, power @ coil, signal to coil etc PWR to ecu) but after trying for 2 days to get the thing to start, I plugged in a dizzt from a 1.8, spun it by hand and got fat spark, THEN plugged in currently installed dizzy and the car started first time..
What could be causing this,
HALL SENDER???
TRANSISTOR IN ECU???
IGNITION MODULE???
The car has the siemens ecu and associated wiring (not sure of original donor) I do also have complete wiring harness and ecu for dig II system and was wondering if this can be ustilised for the 2.0L
ANY HELP OR SUGGESTIONS WELCOME - IT HAS REQUIRED TOWNING ON3 OCCASIONS NOW AND AM RELUCTANT TO DRIVE
it is suh a beautiful little car and to have it sit is extremely frustrating.
I look forward to any insights that may shed some light on this predicament.
Cheers and Regards,
Courtney.
