Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Rear brake caliper
  1. #21
    Oct 2005
    Dandenong North, Vic
    Gave it another purge today with no improvement, although I didnt have enough brake fluid to do more than 3 pumps of the pedal. I use a 1 man bleed kit like this http://cgi.ebay.com.au/BRAKE-BLEEDER-ONE-MAN-AMPRO-QUALITY-NEW_W0QQitemZ360038462769QQihZ023QQcategoryZ35625Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem
    I dont see any air bubbles coming out, looks like a constant stream.
    The bleeder valves are up right at the top of the caliper. Hand brake works ok. I read on some other forums about keeping the brake bias valve open. Where is that ? Anyway the fluid comes straight out as soon as the bleed valves open. Not loosing any brake fluid nor see any leaks.
    More bleeding ? How many more brake fluid bottles ?
    MK2 GTI G60
  2. #22
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    Im a bit sceptical on one man bleed kits .....
    The old way seems to give best results.....
    re use the fluid that u are bleeding , so you dont waste any.
    But like I said...If the master cyl is buggered or a seal is stuffed , when you get the pressure to the pedal and hold constant pressure u will feel the pedal slowly move to the floor and the fluid will by pass back into the resivour.
    A stuffed master cyl usually wont hold any pressure to the braking system for too long...when you pump them up will it hold pressure under your foot without slowly sneaking to the floor????
    And do you get a solid pedal with motor running and hand brake ON.....
    If the pedal pressure is good with the hand brake ON...it usually means a sticking piston in caliper..as I said before...
    but seriously, throw the one man bleed thing away!!!! lol....
    some work great...but allot of them are total S%#T....
    an at least you know you cant go wrong with some one pumping the pedal and doing it the old fashon way. lol
    Cheers, Benny
    www.axesent.com.au
  3. #23
    Camden, Sydney
    Clamp the rubber line to each caliper in turn on each wheel.
    If it improves when you clamp one, you have a problem with that caliper.
    If its the same, I`d be looking at the master.
  4. #24
    Bring this old thread back to Top, and look for help
    I fitted Mk3 caliper in my Mk2 ok, in upside down though (i.e fit left to right and right to left)
    Now it doesn't bleed, I used power bleeder as well as the 2 men method, nothing come out from the bleeder valve. Could it be the bleeder valve blocked or problem with caliper ?
    I also tried to remove the caliper again and turn it over to bleed, still no oil out from the bleeder valve.
  5. #25
    Feb 2009
    NSW
    I had this. I took my caliper off, and squeezed the piston in by hand a few times until no air bubbles came out. It worked the best for me. Took me ages to do it but surprise surprise, I have brakes now!
