reverse lights
if you look at your gearbox under the brake booster you will see a llarge approx 1 inch fitting screwing into your gearbox with two wires attached. If you turn on the ignition and touch the two wires together it should turn on your reverse lights. If they don't turn on you can be sure that you either have no earth, no power or busted globes. If the lights do come on then the reverse switch in the box is shot (the reverse switch is actually the fitting which you pulled the wire off)
luke
77 Golf tarmac rally
89 porsche 911
80 Rabbit 4dr
11 mk1 and 2\'s in various states of undress
KEEPING THE BIG CUBES IN THE REAR VISION MIRROR
