Results 1 to 6 of 6
Thread: Rear axle droning sound
    Feb 2010
    Canberra
    Question Rear axle droning sound
    Lately I've been getting a droning sound coming from the rear wheels/axle. At first I thought it was just the exhaust but I've had that quietened and the pitch of the droning hasn't changed and if I take it out of gear and just roll the noise stays the same.
    The noise itself isn't always there, it comes and goes and usually starts between the 60km - 80km/h mark and lasts maybe 15-30 seconds before going away.
    I've got Porsche D90's 16x8 with 16x7.5 tyres with adapters/spacers.
    I'm wondering if I just need a rear wheel balance or is it something else?
    85' MKII GOLF GTI - GTI 85T - First cruise was 4000km in 2.5 days. It's Evolving!
    06' MkV JETTA TDI - Stock To Shock
    May 2010
    NQ
    May be a possibility but could it be the rear tyre on that side?
    Our Mazda 6 had a droning sound and every mechanic/tech that heard it said "Quick replace your rear wheel bearing"
    Anyway we had the rear tyres changed a couple months later and the sound dissappeard.
    May be a possibility but I'll let the experts put in their opinion.
    Dec 2009
    docklands , victoria
    the obvious first thought is a wheel bearing and spaceers will make it worse. jack it up and try and wobble the wheel.
    could also be a warped disc so give the wheel a spin to see if its catching.
    Feb 2010
    Canberra
    Quote Originally Posted by monkeyalan View Post
    Finally got around to jacking the car up (didn't want to cos I have a crapy jack) but anyway the wheel catches and you can clearly hear the disc catching.
    Where would I go to get it fix/replaced? just a general brake place? Or somewhere else since its an older golf?
    Dec 2009
    Any decent garage should be able to do them (replace both sides at once or you could get a brake imbalance). I think the rear discs are the same as the mk3 2.0 so shouldn't be too expensive or har to get hold of.
    I think the wheel bearings are mounted in the discs aswell so you may aswell change these at the same time.
    Feb 2010
    Canberra
    Will see what I can do as the noise is starting to drive me up the wall
