Results 1 to 10 of 14
Thread: Radiator fan problem.
bam87 Radiator fan problem. 19-10-2010, 10:10 PM
ryana89 Straight out of a Bentley... 19-10-2010, 11:16 PM
walshydub Yep, he's right they all do... 20-10-2010, 08:08 AM
RedMk2Gti I don't 100% believe that, if... 20-10-2010, 08:27 AM
walshydub Mine can run for up to 5... 20-10-2010, 10:15 AM
Munch I have a 1991 Mk2 Golf GTi... 07-09-2015, 11:02 PM
Munch http://www.vwwatercooled.com.a... 07-09-2015, 11:13 PM
Munch http://www.vwwatercooled.com.a... 07-09-2015, 11:07 PM
sports racer I don't have any wire like... 15-09-2015, 01:39 PM
    Sep 2008
    Brisvegas
    Hi Guys, having a problem with the radiator fan not turning off when i turn the cars ignition off. I have to physically pop the bonnet and disconnect the plug to the fan. Any idea's on what to do to fix this??? (I have already looked at my fuse box, and its not wet or fried). Ironically this happened wed last week when there was massive downpour.
    VW Golf 1990, GTI.
    Cheers, Blake
    May 2010
    NQ
    Straight out of a Bentley Workshop Manual for this model car.....
    "On some models with gasoline engines, a cooling fan after run system, operated by a control unit on the fuse/relay panel, runs the cooling fan for as long as 15 minutes after the engine is shut off, as a guard against starting problems which may be caused by high engine compartment temperatures".
    Its normal, and a feature many older European cars have.
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    Gold Coast
    Quote Originally Posted by ryana89 View Post
    Yep, he's right they all do it. All my Mk2's have done it from a 1.3 to 16V GTI
    You are probably doing more harm by disconnecting the fan...
    I don't 100% believe that, if the fan keep running up to 15 minutes after the engine is stopped something must be wrong. The longest that I've seen in my car is about 1.5 minutes.
    Gold Coast
    Mine can run for up to 5 minutes on really hot days. Sometimes it runs for a minute or 2, stops for a few seconds the starts up again for a few more minutes. It's never bothered me as all my MK2's have done it.
    15 minutes would be a little extreme but the fan would keep running until it got the temp down to a level where it would automatically shut off.
    I don't think it is anything to worry about but unless it keeps on running without ever switching off.
    May 2010
    NQ
    Its the job of a little sensor in the back of the engine bay (near the manifold) that decides when the fan run on feature is engaged or not, according the the Bentley Bible.
    I think 15 minutes might be possible if the car has been red lined or been doing extremely hard work for the past 5 minutes and if the outside temp is high (say in the 40's)
    HAHAHA
    Mar 2015
    Perth, WA
    I have a 1991 Mk2 Golf GTi 8V. Genuine Australian.
    I have a loose, spare wire near the ignition coil and believe it should be attached to the radiator after run switch.
    The problem is, I can't find the switch????
    The wire is brown with an OEM female spade connector with OEM rectangular insulating shroud.
    It also has black insulation over the brown wire. Everything points to it being OEM.
    The wire is attached to the external side of the main engine loom and separates near the ignition coil.
    There is about 8" of wire, but for the life of me I can't find anything for it to connect to?????
    HELP!!!!!
    Mar 2015
    Perth, WA
    Attached Thumbnails Attached Thumbnails Radiator fan problem.-3-jpg   Radiator fan problem.-1-jpg
    Mar 2015
    Perth, WA
    I don't have any wire like that on mine but I do have a lot of wires that aren't connected. I've even got doubled up plugs for the front indicators and parking lights that aren't connected.
    My radiator fan used to work fine before I did a gearbox swap. After the swap I plugged all the wires back where they were supposed to go but the fan kept going for 10 minutes when I turned off the ignition. I bypassed some of the wiring and now it works normal but I've got at least 3 connections that aren't plugged.
    Everything works so I'll leave it like that.
