Straight out of a Bentley Workshop Manual for this model car.....
"On some models with gasoline engines, a cooling fan after run system, operated by a control unit on the fuse/relay panel, runs the cooling fan for as long as 15 minutes after the engine is shut off, as a guard against starting problems which may be caused by high engine compartment temperatures".
Its normal, and a feature many older European cars have.
