Results 1 to 10 of 10
Thread: Problem after lowering
    Feb 2007
    I got myself a set of hottuning coilovers and instaled them today.
    I installed them and wound them down all the way. I have only done the front so far.
    The problem i have is, when i turn right, even slightly you can feel bumps as if there was a large lump on the tire.The faster you go the worse it is.
    I have checked everything was tight and where it was suposta be. I checked the tires and most things i could see. Its not due to rubbing of the tire on anything as far as i can see and it doesnt sound like it is rubbing. The sound is more of a pulsing thud, you can feel it more through the floor than the steering wheel. Im prity much out of ideas on what it could be. The last time i had a sound like this was when i had a ball of duct tape stuck on my tire and when i didnt tighten my wheel bolts.
    Can anyone help?
    MK1 GLS 3door
    A4 B7 2.0T
    Sep 2007
    tighten the wheels up? is everything nice and torqued up?
    you should probably go for a wheel alignment. your suspension geometry isn't going to like being 5 inches higher in the wheel arch..
    87' MK2 GTI
    13' MK7 TDI
    Feb 2007
    Quote Originally Posted by jayjay View Post
    Everything is tightened up and tripple checked. My wheels where badly miss aligned since i installed lowering springs. When i installed the coil overs i set both wheels to max negative camber as i didnt have enough to mesure it properly with.
    Ill try and raise the car a bit and see how it goes. I rekon it might be the steering arm touching somewhere when i turn.
    Any other ideas?
    MK1 GLS 3door
    A4 B7 2.0T
    What about coilover rubbing on tire ??
    What about those metal clips that hold the brake line on the coilover? It could be rubbing on inside of the wheel.
    take the wheel off completely to check for marks.
    If you wound them down all the way, it might be bottoming out on the bumpstop.
    But I'd be checking steering arm, control arm & mainly driveshaft clearance.
    Also, if you've got them at max neg. camber, the tyre maybe rubbing on the spring's.
    Feb 2007
    Quote Originally Posted by Soundofav6 View Post
    I tripple checked everything then once again with a mate. Ofcorse the wheel was off. All of the rubbing marks came from my 16x7.5 that i was running before i had the coilovers.
    Quote Originally Posted by golfworx View Post
    Ill have another check to see if it is rubbing on the spring, but there where no marks as far as i could see.
    Clearance seems to be the problem. I raised both sides individualy. It seems to be the left side, the steering arm is alot higher on that side. When i raised it the noise reduced and only does it when you turn right hard. Im guessing it because the car leans on the left and it touches somthing there.
    I guess i cant have it as low as i would like untill i get the tie rods flipped
    Thanks guys.
    MK1 GLS 3door
    A4 B7 2.0T
    Oct 2006
    Did u get a wheel alignment done after installing?
