Just realised front subframe was initially different for engines with additional PAS cooling line, but now all MK2 subframes are superseeded with the one type 191199201D as replacement. Follow the yellow lines
I was going to drill like you said but the fitment is poor on the bar I have so for what its worth (many say junk it anyway). I would prefer a good photo with one fitted so I can have a better look. What with the one on your drive ?
Not sure if this is any help, but do you have a support bar like this ?? I thought this supported the PAS pipe ?????
Yes, I have that support but its for the hose. I have decided to mount the cooling pipe and make it fit the best I can. I will do a pic when Im done. Thanks.
Get rid of the pipe and put a small auto trans cooler in front of the radiator.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
The lad spent 250 bucks on the pipe, no one else will want to buy it if he doesn't use it.
Thats what I`d do too, but it wouldn`t be original.Originally Posted by aprr32
This is the best I can make it fit. Look familiar Gavin (h100vw) ?
Looks factory to me apart from the green padding.
I have this support for the hose, but can someone post pictures wher its mounted ?Not sure if this is any help, but do you have a support bar like this ?? I thought this supported the PAS pipe ?????
