Results 1 to 10 of 16
Thread: Omg! :-s
    Sep 2006
    Parkinson / Brisbane
    Omg! :-s
    Ok, so I bought the jetta and it had a musky smell about it, I deodarised and was smelling better than ma VR6! problem solved . . . sorta . . . As I was installing ma new window winder mech today i noticed the smell had come back really strong! I glanced into the back passenger foot well and HOLLY POOPOO ...
    Attachment 972
    Attachment 973
    noticed a lil bit of wetness on the rear seal here
    Attachment 974
    and also wetness on the front seal
    Attachment 975
    Though i'm really not sure on where it has entered?!?!?
    I'll have a better look tomorrow, but if anyone can shed some of their experiences on it would be much appreciated!!
    Cheers! . . . Alex
    Mar 2007
    sydney
    i had the same problem with my mk2, i did not have the plastic on the in side of the door cards, and the water would go into the bottom of the door and when the door is closed it would come in, i had all the carpet out of my mk2 plenty of thimes till we found that problem good luck mate, who had the jetta before you not many mk2 jetta around
    gpk_gti Guest
    hey alex,
    what you do is,get someone to hose the car whilst you are inside the car.you should see where it is entering the car.Id say its your top seal around the door.
    I absolutely hate water leaks in a car,,bloody stinks!!!!
    Jan 2007
    South Australia
    WOW thats wet
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Point Cook, Vic
    eeek nasty! hopefully u still have a floor!
    FOLLOW US ON FACEBOOK
    Penrith, NSW
    Did you take a corner too fast or something?
    I get a slight leak in that same spot in heavy rain or when i wash it but doesnt get anywhere that wet, mie is in the top of the window seal I think.
    1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
    Aug 2005
    Sometimes the seals shrink with age and then they don't touch the right parts of the door. Happened to my mk2, luckily friends had some spare seals.....no problems now.
    Boronia VIC
    Check the drain holes in the underside of the doors. What can happen is the doors fill up because the window scrapers aren't doing their job. When the door gets full enough the water overflows into the interior of the car.
    I doubt it's your door seals, they're doing an excellent job of keeping the water in!
    Pete
    Aug 2005
    The seals are a known problem with older MK2s, don't rule them out totally but I would agree to check what other people have mentioned first. I have posted it up because it is not the most obvious thing to look for. Had my door overflowing in one of my MK1s ages ago to. Good Luck.
    Jun 2007
    Country Victoria
    Wet
    I had wet carpets due to a blocked drain hole in the rain tray, When the car was parked the rain tray would fill up and enter thru the fresh air vent.
    Some how this water pooled at the rear after driving.
    Not sure if MK1 and 2 have the same drain holes but worth a look.
