Results 1 to 1 of 1
Thread: Oil Temp sender/sensor
    Jan 2016
    Georges Hall, NSW
    Hi guys,
    just doing some more work on the car and wanted to get the MFA Oil temp to show on the dash. It hasn't worked since I've had the car.
    So I ordered Part 049919563A from FCP and it worked fine until I stopped the car and realized that it was leaking oil from the base of the sensor. In my wisdom, I thought I would be smart and tighten it up with my ratchet. But I went to far as it sheared the head off the new sensor and I had to fish out the copper thread
    I've put the old one back in until I get another.
    Can i just confirm that the above is the correct part number and if I can replace the metal washer on the sensor to a rubber one? I thought that might help me get a tighter fit. I would take out the sensor myself and check the part number but can't be bothered waiting the the engine to cool down lol
    Image below of sensor before I tore off the head.
    Attached Thumbnails Attached Thumbnails Oil Temp sender/sensor-p_20161113_101031-jpg
    VW MK2 Golf GTI 8V 1991
    VW MK3 Vento 1995 Daily Driver
