Results 1 to 8 of 8
Thread: Oil cooler sealing to flange
    Oct 2005
    Dandenong North, Vic
    Does any body know what to use for the sealant for oil cooler to flange ?
    Bentleigh lists to use AMV 188 100 82 ? I can not find this anywhere even the dealerships state its not on file. Do I need a sealant or is the O ring enough on its own ? Any body know ?
    Camden, Sydney
    Go the O Ring. Maybe with a film of oil, like a filter.
    I`ve never used sealant and my motors dont leak.
    Apr 2006
    Hobart,Tas
    If this is what the sealant is for,I only use a light oil or grease too
    syncro Guest
    Re: Oil cooler sealing to flange
    Quote Originally Posted by aussieg60
    Bentleigh lists to use AMV 188 100 02 ? I can not find this anywhere even the dealerships state its not on file. Do I need a sealant or is the O ring enough on its own ? Any body know ?
    It is listed on their ETKA as sealing paste.
    Golf 1990 Illustration 13-20 (text only)
    Oct 2005
    Yes, but not on file or available from the dealerships, not so important anymore for the oil cooler but more so for the plate to block as in my other post, Sealing Pastes
    but Bentley again says to use AMV 188 001 02 paste on the G60 block where there is a plate to seal off the hole for the coolant passage into the block on the cam belt side.
    [/quote]
    syncro Guest
    I don't really understand why it is not available from dealerships??????
    If it's on their ETKA they should be able to get it.
    Are you sure that they are trying?
    Oct 2005
    I will give them another try, but every time I have asked they reply with Not On File, whatever that means.
    syncro Guest
    "Not on File" is cryptic for "can't be bothered."
    Give him the illustration number/engine code/year (1990) etc.
    Tell him he's a 027 115 611C
    I hate VW spare parts people
Similar Threads
  1. VW Sealing Pastes
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 25-05-2006, 08:25 PM
