Bring it to TDC and pull out #1 plug lead or remove and earth the plug. Turn the motor by hand and make sure it sparks at the right time. If it does, this eliminates timing as the problem.
Pull an injector and with the ignition on and the throttle plate open you should have fuel.
If there's fuel, a spark at the right time, and compression the bloody thing should run! (Well, it got past the Oz censors!)
