Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Non starting kjet / dissy advance?
    Camden, Sydney
    Yeah I know that Guys.
    What I want to know is this:
    The engine is running without a computer, just kjet, not ke-jet.
    Obviously it does not have a vacuum or mechanical advance from the dissy. Does this matter? Why?
    If it does matter, can I butcher a polo or similar dissy that has mechanical advance and whack it on.
    I want to know this, not just for me, but for others out there running 16vs on basic kjet systems. You know who you are.........
    The only symptoms so far seem to be a lumpy idle, which could be a cold start reg or something anyway. I drove the car back 3 feet today.
    Wahoo, but I still need a fan and an alternator bracket and some other bits. Its going for a blatt round the block very soon though. Sounds hectic when you free rev it!
    imported_brackie Guest
    Fan
    I've got a fan if you need it
    Perth. WA
    Quote Originally Posted by Golf Loon
    ""Yes it does matter, the computer and knockbox in the CIS-E set up does the engine timing chore, advancing the timing point when engine speed increases etc.. For use with a CIS Basic set up you will need a saab distributor with the vacuum advance mechanism in it, [ from my text archive...16V dist. Vac advance type, use SAAB, 900 8Valve , 1982 - 1985.] ""
    ""Dunno, anythings possible i guess..:roll:""
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Camden, Sydney
    I have a saab dissy, but it fouls on the Master cylinder. Can I raise the bottle up with some hose or something?
    sydney
    just a thought, why don't you unbolt the booster and kick it from behind there. Its a but further back from the dizzy and you might just get enough clearance.
    Camden, Sydney
    Quote Originally Posted by 82cab
    What?
    Jul 2005
    Get a 1500/S Bug/Type 3 brake resovoir and mount it on the strut tower an connect it with some hose, works for all the 16v conversions that we do.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Camden, Sydney
    Quote Originally Posted by aprr32
    Nice. What do you connect at the MC end? a connector, or just jam some hose in?
    Golfwise Guest
    little right angle connectors.
    Come on use some imagination.
    By them at Repco Bursons sort of place.
    Beetles or Kombis have them but I won't touch anything aircooled.
    Mk3 abs have little green ones I've used before too and the Golf resevoir.and a bit of hose.Too easy :roll:
    Camden, Sydney
    Yeah sounds good. All I need now is a saab dissy. The annoying thing is that I have one somewhere. I have looked for ages, but I cant find the damn thing.
Similar Threads
  1. kjet probs
    By Golf Loon in forum Mk2 Golf & Jetta
    Last Post: 29-04-2006, 07:43 PM
  2. Mate!. Need to borrow a Dissy for elimination
    By Volksfolks in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 06-10-2005, 12:27 PM
