How does it have a 2E bottom end from the factory?
Is it Kjet or Digi?
Without a O2 sensor on a Digi your fuel economy would be terrible, dunno about Kjet.
After checking over everything I can now confirm my car does NOT have a catalytic converter or O2 sensor.
It was imported from Africa with a factory 2E bottom end.
It also has a 4 in to 2 exhaust manifold on it aswell (not typical of a RV head?).
Did South Africa have lower emissions standards?
Also where would the connector/plug be for the O2 sensors harness/plug?
Getting an average of 15 litres per 100K, is that typical of a car with no O2 sensor, or should I check over other components?
Any comment or ideas are welcome cause Im at a dead end atm.
Ill posts some pics up later.
Thanks
EDIT: had a chat with the previous owner, and it came to Australia without a cat/O2 sensor.
South Africa did't have high emissions standards?
Either way, an O2 sensor improves/helps fuel economy wouldnt it? Somthing anybody in any country would want....
Is it Kjet or Digi?
MK1 GLS 3door
A4 B7 2.0T
VW built plenty of cars that don't have cats or lambda probes. Not having one fitted, assuming it shouldn't have one, wouldn't make the consumption double.
Is it digifant/electronic or K-jet mechanical?
And as I said, here are some pics (if you dont know what a catless MK2 looks like)
Off the 4 into 2 manifold into the dual downpipes
Downpipes bending to go towards the direction a cat would be in...
Downpipes eventually merging
And BAM no Cat.
Now this little 2 wire plug wouldn;t be where the O2 sensor harness usually plugs into would it?
What's the part number of the ECU? That'll tell us quite a bit.
037 906 022
Not as helpful as I had hoped. I couldn't find it on ETKA. google threw up a couple though which makes me think the ECU is from a 2 litre Passat. I can't tell which year though. I know that the very early MK3 GTIs that had this engine, didn't have cats fitted in the UK.
So it is entirely possible that there is no cat/lambda needed. Could be any number of reasons yours is using lots of juice. Coolant temp springs to mind.
Thanks!
Have a funny feeling this car is a bit of a mix of VW parts.
(Blue) Coolant temp sender is the next thing to be replaced.
Going to save up and get the injectors removed and cleaned/rebulit too, maybe replaced if needed.
If it does have a O2 sensor harness to the ECU, then I may get an exhaust shop to weld a bung into my exhaust for a Oxygen sensor to mount into
One day![]()
Post a picture of the engine bay for me. Lets see what else isn't from the original car. It is easy to put a 2 litre bottom end in but has it got a full 2litre engine fitted??
PS I think having the injectors rebuilt isn't worth the dollars.
