Originally Posted by
peedman
When you say that u found this plug near the 4th cyl runner do you mean on the passengers side or the drivers side? Just trying to clarify because the cylinders are 1 2 3 4 when looking from the front of the car so the 4th cyl would be on the passengers side. The o2 sensor plug is normally found on the drivers side.
Other than that i cant really help you. Ive looked it over and over and each time i reach a conclusion i realise i am wrong and get more confused.
If i were in your position i would wire it up as you see it i.e. like the mk3 plug and see if it works. After all there are only finite number of possibilities!
