Results 1 to 10 of 13
Thread: need new mk2 clutch
    Jan 2008
    need new mk2 clutch
    as stated, need new mk2 clutch, no more than 150 bucks. anyone know of anyone who sells em?
    i can import but thats a waiting problem.
    thx
    Golf MK2 Project
    Daily car: Audi 90 2.3L 5cyl manual
    "I run everything under pressure, from my supercharger to my blood"
    Jun 2006
    Hornsby
    you chasing just the disc?
    Jan 2008
    hmmmm, good question.
    now im a mechanic but i never ever thought to pay attention to gearboxes. guess now comes as a problem.
    well all i know is my clutch is slipping so i need new one. dont know if its pressure plate or not.
    all i know is i can get a whole clutch plate n disc or what you may call it.
    dont know words in english.
    for around 100 bucks.
    so im guessing would be bit more expensive so i say 150.
    its random slippage.
    1st gear no slippage none in 2nd either but 3-4-5th gear it just slips when i accelerate.
    so any help would be nice.
    ill find out 2mo what i need exactly
    Golf MK2 Project
    Jun 2006
    Hornsby
    odd, machine your flywheel so that its level and stops slipping, you might find your disc is worn or your pressure plate is f'd take the clutch out mate and have a look,
    its a good idea to replace the release bearing and some seals at the same time.
    if you have never seen a mk2 clutch they are opposite to most cars aka, it doesn't go flywheel - disc - p.plate. the mk2's go pressure plate, disc, flywheel,
    replace the bolts too.
    Camden, Sydney
    Dont machine the flywheel as it will then slip for sure.
    You need a full clutch kit. $300 brand new.
    Update your location in your profile so we know where you are. Maybe someone round the corner has one.
    Jun 2006
    Hornsby
    ah ok, this guy was trying to get me to machine mine, lucky then.
    Aug 2007
    Just remember you have a back to front clutch set up there, if the flywheel is scorched then you will need to find someone with a jig who can reface or you will need a new one or a good second handie. If it has only just started slipping then try and limit it mate till you do the job. There is a few other things to consider while you are in there. Condition of the release plate, rod and of course the rear main oil seal, now would be the sensible time to chage that.
    Jmac
    Alba European
    While on this subject, I just pulled the box from my Toledo. Don't be surprised Matt, I said I was doing it this weekend.
    Anyway, I have a flywheel, plate and cover that aren't in bad condition. If you want them. You can have them for $25 plus postage. Need to check the number of splines on the disc.
    Not to say Jimmy isn't right about the RMS but the only time a did a precautionary one. I damaged it and it dumped oil on the new clutch. So, in my world where I don't lose sleep having to do things twice, if it is dry, then leave it be!
    Camden, Sydney
    I am suprised Gav, good work tho.
    Thats a very cheap price for a clutch mate, getin there for the budget option. It wouldn`t have done many ks that unit.
    Hate to throw it away if it's useful to someone. That's the Yorkshire in me!!
    Pretty much sorted the Toledo. Need to hunt down some starter motor bolts, got the Audi ones somewhere I reckon. Fit the clutch cable and bolt up the driveshafts. The inner CVs had about half a pint of gearbox oil in them !
