Clutch, What to use and where to get it from?
KR 16v Motor and an 020 gearbox.
And while I think about it where to get an overhaul kit to suit said gearbox that includes replacement sycros?
Thanks in advance
Yer,
You need
Bearing seperator
Bearing pusher (CJ83)
Brass drift
Hammer
CRC
Sockets
Ratchet
impact gun
Air Chisel
Knock yourself out
500 Series Hino - 99 V6 PASSAT Daily Driver
84 MK2 GTI 16v - 88 MK2 GTI 8v Donor
Thanks in advance
Anyone had this problem? The earth point on the fuel filler neck has rusted, it's to small the weld, and it seems to be moulded into place, I've tried to solder. Any ideas?
I got my 210mm 16v sachs clutch from German Auto parts in America.
Can you make up a tab and braise or weld it on?
Have you got a TIG?
Though welding may be too much heat and melt the plastic.
Could you drill 2 small holes, put wire through it (solder the wire back on itself) then attach to an earth?
MK2 - *Insert list of dealer purchased extra's/standard features here*
80 series - The MK2's BIG, Sooty, polar opposite...
HAHAHA
Liking the drill idea thanks for the clutch info![]()
mmmmmmmmmmm.. thats what i like to see, powerflex!!!
I have a kr clutch kit in good condition. Pm me if you want it.
83 Audi ur quattro
