Originally Posted by
Golf Loon
The top picture is a Golf 2 hub with the built in carrier for the caliper. This is the same as those forund on 1.8 cordobas or Golf 3 1.8 CLs.
The Next Picture is a Mk3 GL 2L Hub with probably a VR6 hub pushed into the bearing and gawd knows what disk.
Good Luck with finding out from Brian, he cant use a spanner so would have got someone else to do it for him and his altzimers is coming on so he wont remember the details anyway.
Easiest fix is probably go back to 4 stud. What about that hub I sent to you? That was a 2L GL one I think, the caliper on the car should fit it, change to a 4x100 disk and you are in.
What stud patern are the rear rotors you bought??
