Here are my suggestions.
- wipers - Take the ones off your red car
Already did, its just dirty
- parkers are blue - Take the ones off your red car
Already did, he thinks white LED is blue
- dash lights all need to work - Take the ones off your red car
Pain in the arse, its the guages so i need to do the whole neon thing again
- front grill needs to be secure - Cable Ties
God bless them
- no number plate globes - Take the ones off your red car
I need to take the whole hatch from the red one was the one on the car now is rusted through where the globes go
- secure and mount radiator - Take the brackets off your red car or use cable ties
Why didnt you do it? ![Biggrin](https://www.vwwatercooled.com.au/forums/images/smilies/biggrin.png)
![Emo Nana](https://www.vwwatercooled.com.au/forums/images/smilies/emo_nana.gif)
- no timing belt cover (do i use a mk3 cover?) - It goes on the head, so its a 1.8 one, take the one off your red car
As you know its a tall block so it doesnt reach all the way down, i hope he doesnt notice
- front shocks - Take the ones off your red car
Can i pass with coilovers?
- exhaust mounts - Take the ones off your red car
Pains in the arse they always brake
- rear wheel bearings - New ones are cheap as, or - Take the ones off your red car
Ordered
- secure wires under front bar - Cable Ties
- passenger side seat is loose - The rectangular block that goes on the seat base has come off when you have swopped the seats, replace it
- wash motor and repair oil leaks - degrease and clean
- p/s drive shaft boot - Take the ones off your red car
- drive shaft seals - Take the ones off your red car
- p/s lower side skirt trim - Take the ones off your red car
- refit fog light - Take the ones off your red car
They caught fire on the red one haha
- 2 new tyres - Good Idea for safety too.
- front rotors - VR6 Front ones from TIM or Imparts or me.
Funds = low
- rear rotors - Take the ones off your red car
- p/s tie rod end boot (wtf is that?) - Take the ones off your red car
- possible water leak Check, but I dont think so, tighten hose if so
I cant find what hes talking about
- accelerator pedal rubber (Mk2's dont have one do they?) - NO
Thought so
- front engine mount - GAP or Imparts or CGTI
Ordered
change it back to 4x100 stud pattern and use the bbs wheels.
You could do that and sell the 5 stud conversion kit. You should change the whole front legs if you are going this route and the rear disks etc. That will fix a few of the probs above too.
Unrelated to the RWC, i want to know why my 2nd gear ALWAYS grinds when i slap it from 1st to 2nd quickly, it did it on the red one aswell and its only in 2nd. keep in mind the box has been rebuilt. Is it just what they do or is they syncro no good?
Its a linkage issue usually, which can also be caused by engine mounts being worn, causing the gearbox to move, when you need it steady to change. Prolonged linkages not being adjusted causes wear in the boxes.
Just dont slap it into 2nd and you will be fine.
Better get to work mate, should be a good Mk2 when you are done tho.
