Its got about 10L left in the tank.
I tried to sort out the idle again today after work, i followed what it said in the haynes manual (warm it up, plug breather hose, unplug temp sender, rev 3 times blah blah blah). It didn’t to anything.
I then tried to sort out the timing following the Haynes manual and a DIY post on clubgti.
Im a bit puzzled. I found TDC through spark plug hole #1, at TDC the cam pulley mark lines up with the other mark, all good right? I then adjusted the dizzy so that it matches up to the rotor, at TDC it lines up with spark plug #1.
I had a look inside the hole on the gear box and the notch, that i understood should be there, wasn’t there. I turned the engine by hand to see where the notch was and when i found it, the cam pulley was no longer aligned and neither was the dizzy.
From what i understand when the engine is at TDC the cam pulley and the notch in the gear box should be aligned with their respective points.
Please correct me.
Matt, when you said it might hunt up and down when its cold but then its fine, its the other way around. When its cold it idles fine but when it warms up the idel increases and hunts up and down, even when i hold it at 2k and 3k rpm it will still go up and down (not as much as on idel but you can still see it).
