Page 1 of 9 123 ... LastLast
Results 1 to 10 of 82
Thread: My new Mk2.
    Feb 2007
    My new Mk2.
    Thanks to Matt, Dad and my gf I got myself another mk2, one that isnt smashed. The first thing i did was cut myself on the gear nob, off to a good start i think.
    I got it for a fair price, the same price i paid for the red one and funnily enough it is in about the same condition as when i got the red one.
    Here are a couple of pics I snaped today before i got stuck in to it.
    It looks alot worse in person haha. It very very dirty in side and out but it goes prity hard.
    I got it with a 2L bottom end, rebuilt box and vr6 brakes. I have also been told it has uprated sway bars and shocks but i have to double check these things. Its prity amazing to drive compared to the red one, ALOT more power.
    So far i have:
    -changed the mirrors with working ones
    -fixed the passanger side central locking
    -fixed the shift linkages
    -fixed the horn
    -re-atached the bumper and spoiler (still needs work)
    -changed the vacume lines
    -changed the ISV (but the idel is still crap)
    -changed some of the cooling pipes
    -swaped the air box out (too many holes)
    -changed the wipers
    -re atached some bits and bobs
    Things that need doing off the top of my head:
    -front engine mount
    -at least 2 new tires
    -timing
    -the rear end needs to be redone, the hatch isnt painted on the inside and has been badly repaired
    -the car steers by itself sometimes when your on the gas
    -brakes need bleeding
    -new head lights and grill
    -idel issue
    -crack in the windscreen
    -cosmetic stuff
    Im sure the list will get bigger once i book it in for a road worthy check.
    The mods that will be done:
    -ss exhaust including downpipe
    -sterio (can you say 140db)
    -interior will have some minor work done
    -coiloveries
    -electric windows
    -alarm
    etc..
    .....and ive lost my train of though
    I will keep this page updated as i go along, hopefully it will turn out a bit better than my red one.
    *EDIT*
    Things to do for RWC:
    - windscreen
    - wipers DONE
    - parkers are blue DONE
    - dash lights all need to work
    - front grill needs to be secure DONE
    - no number plate globes
    - secure and mount radiator DONE
    - no timing belt cover DONE
    - front shocks
    - exhaust mounts DONE
    - rear wheel bearings
    - secure wires under front bar
    - passenger side seat is loose DONE
    - wash motor and repair oil leaks
    - p/s drive shaft boot
    - drive shaft seals
    - p/s lower side skirt trim
    - refit fog light DONE
    - 2 new tyres DONE
    - front rotors
    - rear rotors
    - p/s tie rod end boot
    - possible water leak
    - front engine mount DONE
    MK1 GLS 3door
    A4 B7 2.0T
    Eastern suburbs of Melb
    Jan 2007
    Excellent work there mate, good to see you've gotten stuck into it after your unfortunate incident. Silver is also a good colour for MK2's methinks
    Oct 2006
    sydney
    sounds like your control arm bushes need replacement..
    when you step on the gas it pulled to the left it happened to my car
    Jun 2008
    gold coast
    Same colour as mine... go the silver
    Aug 2006
    Melbourne VIC
    I thought it was JayJay's care for a moment... Nice! Now it will be easier to get those Porsche wheels on
    As always u will deliver the goods with wicked build-up...
    Jun 2007
    Eastern Suburbs Melbourne
    Nice one mate, good to see you're back on the horse!
    What's the go the the red one now?
    i like volkswagens
    Feb 2008
    nsw
    im sure that was brians from gti imports awhile back??? i can tell cause of the 5 stud.
    a4 1.8tq,s4 mirrors,genuine,a8,wheels,black side markers,rs4 grill, apr r1 dv,neuspeed springs 2" drop waiting for haltech ecu
    Camden, Sydney
    Yeah it was Brians many moons ago.
    He did the 5 stud, dunno how as its still Mk2 subframe and not widetrack.
    It also used to belong to Beau the crazy yank more recently.
    Dunno about the swaybars, they look stock, but it definately has koni inserts in the front and koni yellos on the back.
    It has a Mk3 manifold, downpipe and Cat.
    Its probably just the stock 1.8 cam, but thats ok, with a 1.8 head on a 2E bottom end. Its a hydraulic head, you could stick any cam in it. I`d get it running right first tho.
    Tuning wise, i reckon set the dissy timing so it doesnt ping. Why did you change the ISV? It hunted for a minute when cold like they all do then ran ok.
    Did you get the spoiler, that was totally attached when it got dropped off at the freight depot?
    Is the interior the same as the Red one? I`d have to sort the drivers seat.
    Glad it goes hard and you are happy, will be a sweet Mk2 if you can make it look as good as the red one and at least you have untold spares
    Feb 2007
    Quote Originally Posted by william View Post
    It pulls all over the place as far as i can tell. Ill check it out though, thanks for the tip mate.
    The red one is going to be used for parts, whatever i don't need will be sold or kept or thrown away.
    So its not vr6 brakes? Ill have a closer look tomorrow.
    I changed the ISV becuase i thought that was the problem. It had the same problem as the red one when the ISV was dirty. You would rev it and the revs would sink then go back up, but thats not the only idle problem. I knew my one worked and was clean, so just to be sure basicly.
    The spoiler and the side skirt where IN the car not ON it when i picked it up.
    Its no the same interior as the red one, different color. The door cards are going to be done is suede and ill do the seats later in something else.
    At the moment im just looking to get it running properly, road worthy and registered. The rest can wait.
    MK1 GLS 3door
    A4 B7 2.0T
