Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 105
Thread: My mk2's
    May 2012
    dont worry, just found the problem with number plate light.
    the old common problem of the wires getting pinched in the door, ill fix that tomorrow
    May 2010
    NQ
    Think I'd better add some of you "done" list to my "to do" list.
    Must drive much better with the new gear linkages?
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
    May 2012
    yeah gearbox feels sooo much nicer.
    it idles really weird too, thats something i want to fix. it like seems to like slightly go up and down in revs, is that just something about the tuning?
    Quote Originally Posted by Surfpig View Post
    Swinging at idle is usually the idle stab valve full of oil residue and generally gummed up.
    If you remove it and fill it with degreaser, then clean it out with brake cleaner after letting it sit for a while. I bet it runs nicer. If not you might have an air leak somewhere.
    You should also clean the tickover adjuster on the throttle body. The bypass port will be full of the same gunk as the ISV. I always polished the screw with brasso or metal polish. They stay clean for ages if you do. Check the condition of the O ring on the screw. I used to see loads of split ones back in the UK.
    Look up 'Digifant timing adjustment' in google. To set the timing you need to disconnect the water temp sender and rev the engine 3 times or something IIRC. Then set the timing with your strobe light.
    Jul 2011
    NEWCASTLE NSW
    Is this thing in Newcastle ? Saw u mentioned euro auto centre !
    May 2012
    yeah man, i live in merewether.
    im just about to go to vans workshop and get the blueslip.
    May 2012
    few photo's from the weekend.
    currently getting rid of that pink stripe, and trying to organise my stock wheels to be widened.
    thinking 15" 8" et20 and maybe et10 for the rear.
    Dec 2008
    Bentleigh, Melbourne
    thats looking sweet!!
    you should get some 'forever black' on those bumpers tho
    May 2012
    cheers man, i did that a while ago but has worn off. needs a proper detailing too
    Feb 2009
    NSW
    What colour code is it? I have some detextured front/rear/skirts/flares for sale. Could do with a respray, but at least you can get black with black and not have it fade on you.
