Page 5 of 25 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 245
Thread: My Mk2 Golf GTi
  1. #41
    Sep 2007
    Looks pretty good mate. Any thoughts on engine conversion yet?
    tommy, i dunno about 4 grand for a 1.8t swap..
    Assuming free labour (internet DIYs are gold, up until the point where US/UK spec cars differ to Aussie spec):
    16v ABF swap
    pros: bolts into mk2 subframe, can use 020 transmission, scope of tuning with standalone
    cons: won't make as much power on standard electronics, less local availability
    needs:
    wiring harness and ECU to control fuel (can use OEM or standalone)
    ignition system - different coil depending on ECU
    cooling system - OEM or modified original
    12v VR6 swap
    pros: good power/torque standard, local availability, sound, online conversion support
    cons: heavy, not as much scope of tuning, can't use 020 transmission
    needs:
    mk3/seat k-frame for rear engine mount
    5/6 cylinder bellhousing transmission (02a/j/m etc)
    pedal box for hydraulic clutch (also MC & slave cylinder)
    wiring harness & ECU - OEM is probably simplest unless you're familiar with standalone
    cooling system - routing and radiator completely different
    exhaust system - fanagle, custom or bolt in?
    1.8T 20v swap
    pros: big tuning scope, reasonable availability, can use 020/4cylinder transmission (until it inevitably explodes)
    cons: sensors/parts more expensive, engine more expensive
    needs:
    wiring harness & ECU (standalone is probably easiest)
    (you have to be quite versed in VCDS to bypass/disable immobiliser to use OEM harness & ecu)
    intercooler routing - custom
    cooling system
    exhaust system
    i'd say reasonable pricing for each motor is between $1000 and $2000 depending on condition, kms, extras included (ancillaries, water system, harness etc). You then need something to control that engine - whether it be OEM or standalone, you'll need $1000 to make that work properly. For the VR6, you also need a different gearbox because the standard one will not fit... that's about $1500-$2000. Whilst you've got any one of these motors out, you may as well change timing belts/chains/sensors/senders because they'll bite you in the ass when you're troubleshooting later on. Another $1000. Then having physically installed it, it'll need an exhaust system. Because you're doing an engine conversion for more power, you don't want some 1.5" dialysis tubing choking it up. $500 - $2000. Then it's time to get under the dash!
    So that's $4000-$4500 in parts before you lift the hood of your car.
    87' MK2 GTI
    13' MK7 TDI
  2. #42
    Feb 2008
    Quote Originally Posted by jayjay View Post
    cheers for the post. no thoughts on conversion yet.
    thought i'd post up a couple of pics i took today.
    Today, I managed to uncover the car, and found lots of mould growing on the seatbelts, steering wheel and handbrake. So I ripped the majority of the sound deadening out and found them to be very wet/moist. hopefully that will dry it out.
  3. #43
    May 2011
    Modesto,California
    Looks good
  4. #44
    Apr 2008
    You coming to the Nats in your MK2 on Sunday Russ?
  5. #45
    Feb 2008
    Hey guys, bit of an update for you Bit like Auscare regarding motivation or lack of it due to work and crappy weather, but I have scored a sparco seat and harness from a mate, and just paid for a seat mount base from GSL Rally Sport. So hopefully I can get a seat in there very soon.
    Also tonight I bought off ebay, a Momo Monte Carlo steering wheel + hub. Thanks Auscare again for this, bit of a copy cat, but I liked your style lol. At least our cars are different colours Red goes faster so they say
    Also, I am in the middle of getting a radiator made up from PWR. Expensive yes, but I have searched and searched online for places that do radiators other than OEM replacements or new ones from China, but had no luck. So I bit the bullet this week and posted my original radiator to PWR in Qld and hopefully I get this back soon.
    Managed to rip out all carpet and sound deadening, which again like Auscare, was all wet and rotted away and caused mould inside my car. All leftover sound deadening bits stuck to the floor pan was simply scrapped away with a steel brush.
    I have update Page 1 first post with my costs so far so you guys can tell me what else you think I should be collecting.
    Next thing I have to do is remove the left over AC lines and compressor. Any tips of the compressor removal??? bit stuck there.
  6. #46
    Feb 2008
    Latest pics:
  7. #47
    Jul 2005
    Melbourne, Williamstown
    Looking good Russ.
    If I were making a track going mk2 I'd seriously consider relocating the battery and possibly the washer bottle too.
    And a the best thing I have ever done to my mk2 handling wise was the big anti-roll bars front and rear. Definite 28mm for the rear
    mk2 GTi 16v
    Corrado G60
  8. #48
    Aug 2006
    Melbourne VIC
    What sort of iil filter did you get that cost $32?
  9. #49
    Mar 2008
    Quote Originally Posted by russ83 View Post
    Don't forget money!
    The Monte Carlo is awesome, great purchase.
    Let me know how that goes, I'm guessing I'll need something better than stock later on.
    I also put a pile of rice in the car on a plastic sheet. Has kept all the mould away!
  10. #50
    Feb 2008
    Quote Originally Posted by Water Boy View Post
    i believe it was a standard repco one... this was one of my first purchases and i was keen to spend money.
    have you got a cheaper option for me for next time?
