Still need a flex joint but took it for a spin after working out that the exhaust manifold was loose on one side. Did it up, adjusted the shift linkage as I couldn't get under it to replace the relay bush.
Heaps more power than before. Great pull off the line (Need to change the clutch and the CV's) and great through the gears. But I had a problem when I went, to change gears and nothing happened. I pulled the long shift rod apart and the pin got pulled through and lost on the weighted rod. Jerry rigged it with a useless allen key and pushed the shift rod back together. I shouldn't be able to pull the rod end off should I??? Are there 2 different ball sizes on the shifter linkages?
