check the exhaust movement for tapping noises, apart from that, you'll have to just try and pin point where it is in the engine bay. Ie have someone rev the car and you listen to find where it's coming from. Noises are very hard to diagnose across the internet.
as for the exhaust leak, get a piece of paper (news paper is good, cause it's light and flexible) and hold a piece up against near where you think the leak is. if there's a leak, it should wiggle around as if you were blowing on it. Other method is to cover the exhaust pipe for a second or 2, with a rag, and listen for an increase in pressure being forced out from the suspected 'leak.damaged' area. slightly harder to do, especially if you have a loud ish exhaust.
hope this helps.
