Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 66
Thread: My 1984 MK2 GTi
  1. #51
    Feb 2009
    NSW
    I know!
    Is the oil cap supposed to bounce when you loosen it? Or does it mean the valve stem seals are on the way out?
  2. #52
    Feb 2009
    NSW
    Got the head off.. That was a fun job! Can't get to one of the exhaust manifold bolts, so I popped the clips and took the whole lot out.
    Found a huuuuge amount of carbon buildup- almost like rust scale. Cleaned them as best I can.
    Problem:
    1. The exhaust manifold has 2 cracks in it.
    2. The reco head I have has 4 cam caps, not 5 like my original. There is no provision for the 5th cap (between 3/4 cylinder) Will this matter?
    3. My new tensioner doesn't have a hex head to tension with, just 2 small holes. Should I change it for a proper one or is there a way of doing it?
    What else should I do while the head is off?
  3. #53
    Feb 2009
    NSW
    Exhaust manifold coming soon,
    Gearshift rebuild kit coming. Thinking about trying to clean up the engine bay.. We'll see how I go for time!
  4. #54
    Feb 2009
    NSW
    What does a dropped valve sound like?
  5. #55
    Feb 2009
    NSW
    If I have a leak at the exhaust manifold/pipe on an 4 branch, does it sound like a tap tap sound? It seems to go with revs, but it's so noisy I can't tell.
    Also, It sounds like my engine has a loose bracket. You rev it and it sounds like something vibrates. I've checked all the brackets and tightened up/replaced the snapped alternator bolts. Could it be an engine mount? My front one is a horizontal mount, not the verticle one most Mk2's have.
  6. #56
    Jun 2007
    Eastern Suburbs Melbourne
    check the exhaust movement for tapping noises, apart from that, you'll have to just try and pin point where it is in the engine bay. Ie have someone rev the car and you listen to find where it's coming from. Noises are very hard to diagnose across the internet.
    as for the exhaust leak, get a piece of paper (news paper is good, cause it's light and flexible) and hold a piece up against near where you think the leak is. if there's a leak, it should wiggle around as if you were blowing on it. Other method is to cover the exhaust pipe for a second or 2, with a rag, and listen for an increase in pressure being forced out from the suspected 'leak.damaged' area. slightly harder to do, especially if you have a loud ish exhaust.
    hope this helps.
    i like volkswagens
  7. #57
    Feb 2009
    NSW
    Thanks Jarred. Would a leak at the manifold/pipe are make a tapping sound?
  8. #58
    Jun 2007
    potentially, yes. I had extractors come apart (bolt fell out, and slowly worked the others loose) and it started off as a ticking, but after about two days it was pretty noticeable that is was an exhaust leak. (got much louder)
    hth
    i like volkswagens
  9. #59
    May 2010
    NQ
    A diagram of various MK2 exhaust systems
    4. Exhaust System
    My car had a (slightly) 'tappety' sound in the engine bay when the cap on the CO test/tap tube was removed/broken (see below)
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
  10. #60
    Feb 2009
    NSW
    Cool. I don't have the flex joint in mine (bodged it to get it to run) so I'll get the exhaust dude to weld one in when he replaces my magnex rear box.
    Edit: I take the cap off and it's not any louder.
