i always broke the front mount on the car, so i went to a 16v mount a bit stonger, than i ended up brakeing the mount in half the connects to the motor. yes i did have a mk2 a while ago lots of fun.
Pretty sure the mounts are shot in my car, got bad engine thudding when i back off like the engine is rocking.
What mount(s) commonly go? would it be best just to do a full replacement while i'm at it?
I've also noticed a bit of a knock and vibration somewhere in my front end, not sure if it due to the mounts or something else is up.
Also suggestions on type and where I can get them? locally would be good but not sure how plausible it is.
cheers,
mk4 the mods begin for round 2 hahahha
Get a g60 transmission mount, they are solid rubber instead of the factory oil filled ones. Other than that i dont know much about mk2 mounts
I have a spare oem G60 tranny mount you can have for $25 if you want. But yeah ud probly wanna do the whole set
G60 front mount is good but I have seen even them pull apart. You can make a heavy duty one with the aid of a MIG and a Hacksaw.
I used to make my own out of the big wide MK2 mounts. When you open one up, you find a big lump of rubber with holes. If you fill the holes up, I used some old bolts with the heads cut off. They were just the right diameter, about 6mm diameter.
Squeeze it back together and weld it up.
I'll see if I can find a picture.
http://www.vw-auto-parts-wholesale.c...RhbGxhdGlvbg==
Its probably the one behind the gearbox. The most common to go. I`d use a VR6 one as a replacement.
Thanks guys.
I've found a few places in the US that stock mounts, anyone know of any locally? not really fussed on upgraded ones it's just a cruiser so don't want solid mounts really.
You need a Golf 2, Toledo or G60 front one, the Golf 3 ones are different.
The gearbox rear one can be vr6.
I can get all these locally. I just put the vr6 ones in everything these days, no more vibration, just longer life.
jump on mjm autohaus, they sell a heap of mounts which are uprated - made by techtonics they will do the trick, def upgrade the tranny mount to soild rubber, and my rear mount was cracked when i took it out two weeks ago
