Results 1 to 10 of 10
Thread: Mounts
    Oct 2005
    Nowra, NSW
    Mounts
    Pretty sure the mounts are shot in my car, got bad engine thudding when i back off like the engine is rocking.
    What mount(s) commonly go? would it be best just to do a full replacement while i'm at it?
    I've also noticed a bit of a knock and vibration somewhere in my front end, not sure if it due to the mounts or something else is up.
    Also suggestions on type and where I can get them? locally would be good but not sure how plausible it is.
    cheers,
    Mar 2007
    sydney
    i always broke the front mount on the car, so i went to a 16v mount a bit stonger, than i ended up brakeing the mount in half the connects to the motor. yes i did have a mk2 a while ago lots of fun.
    mk4 the mods begin for round 2 hahahha
    Oct 2006
    Get a g60 transmission mount, they are solid rubber instead of the factory oil filled ones. Other than that i dont know much about mk2 mounts
    Point Cook, Vic
    I have a spare oem G60 tranny mount you can have for $25 if you want. But yeah ud probly wanna do the whole set
    FOLLOW US ON FACEBOOK
    G60 front mount is good but I have seen even them pull apart. You can make a heavy duty one with the aid of a MIG and a Hacksaw.
    I used to make my own out of the big wide MK2 mounts. When you open one up, you find a big lump of rubber with holes. If you fill the holes up, I used some old bolts with the heads cut off. They were just the right diameter, about 6mm diameter.
    Squeeze it back together and weld it up.
    I'll see if I can find a picture.
    http://www.vw-auto-parts-wholesale.c...RhbGxhdGlvbg==
    Camden, Sydney
    Its probably the one behind the gearbox. The most common to go. I`d use a VR6 one as a replacement.
    Oct 2005
    Nowra, NSW
    Thanks guys.
    I've found a few places in the US that stock mounts, anyone know of any locally? not really fussed on upgraded ones it's just a cruiser so don't want solid mounts really.
    Quote Originally Posted by static1800 View Post
    Thanks guys.
    The ones I made weren't solid at all, no extra vibes. Just that style of mount doesn't pull apart like the hydraulic ones do when they fail.
    Camden, Sydney
    You need a Golf 2, Toledo or G60 front one, the Golf 3 ones are different.
    The gearbox rear one can be vr6.
    I can get all these locally. I just put the vr6 ones in everything these days, no more vibration, just longer life.
    Jun 2006
    Hornsby
    jump on mjm autohaus, they sell a heap of mounts which are uprated - made by techtonics they will do the trick, def upgrade the tranny mount to soild rubber, and my rear mount was cracked when i took it out two weeks ago
