Results 1 to 10 of 12
Thread: MKII she not a starting!! Help!!
    Jan 2007
    - Starter motor turns over as per normal
    -Ignition lights working as normal
    - No sound of rear fuel pump kicking in.
    I checked leads, plugs, all seemed ok.
    I called the RACQ guy (came in 10 minutes amazingly!!), he checked everything. he suspected that it is ignition related.
    HE "bridged the gap in one of the spark plugs" and she started first click.
    Cut to last night again same problem. I switched the ignition key on and off a few times and she started, no worries.
    Again this morning- no start.
    Anyone have any ideas what it is?
    Is there a faulty switch somewhere?
    HELP!! i have to go to work this afternoon!! any suggestions would be much appreciated.
    07 GTI
    APR stage II
    Apr 2008
    Did you see what he did when he "bridged the gap between the spark plugs"?
    Sometimes spark plugs have little metal screw on caps that help the spark lead connect to the plug properly. They could be missing or dud?
    Or a further choice could be dead plugs or leads?
    Jan 2007
    Ive checked leads and plugs and they both seem fine.
    Plugs are due for change, but that would not explain why the Fuel pump is not kicking in.
    Leads are only 20,000 kms old.
    Im still thinking its a switch somewhere, as Im not getting the pre start Fuel pump whirring noise from the fuel tank.
    Could it be the pump?
    07 GTI
    APR stage II
    Apr 2008
    Well if you can't hear it then I would imagine so.
    Try this. link
    Jan 2007
    Thanks Benough, thats a great link.
    I might go do a test on the pump circuit to see if there is a fault somewhere there.
    Many thanks
    07 GTI
    APR stage II
    Jan 2007
    Pump circuit test looks a bit out of my ability today ( i dont have any test gear here)
    So i might have to get the car to an Auto Electrician.
    I managed to get the car to start again, the fuel pump is kicking on, so it must be intermittent.
    Just hope it gets me to work and back today!!
    07 GTI
    APR stage II
    Apr 2008
    Let me know how you go.
    Aug 2007
    Switching off and on again to start sounds like you are losing holding pressure. If the pump runs and starts after a few primes then i would suspect a fuel pump no return valve. Very common
    Jmac
    Alba European
    Jan 2007
    Ran fine this afternoon to work and back (touch wood).
    I thought it may have been something to do with the pump.
    Should i just replace the pump or is the valve separate?
    07 GTI
    APR stage II
    Oct 2005
    Dandenong North, Vic
    If it happens again, give your fuel relay a tap and listen if it clicks. Contacts could be sticky, or wiring behind not making good contact to the coil of the fuel relay.
    MK2 GTI G60
