I reckon you've got air in the system somewhere. Or the master cylinder seals have flipped inside out. Try bleeding the master cylinder. If it just has 2 outlets, crack the brake lines and press the pedal, nip the line back up with the pedal at the bottom.
Some aftermarket master cylinders have 4 outlets and have 2 blocked off. You should be able to buy bleed nipples to go in the blanks, making the job easier. M10 x 1mm IIRC.
Also, when doing the back brakes you should set the rear bias valve, as though the car was fully loaded, this allows the maximum amount of fluid to the rear.
