What wheels/tyres are you running?
I have cheap coilovers and they are mega stiff with the 195/50/15's that I'm running. Every bump in the road shakes the car. With 185/60/14 they are fantastic.
I am planning to fit a set of vr6 shocks with mk2 eibach lowering springs, is it going to be too stiff? Anyone tried it before?
Sent from my iPhone using Tapatalk - now Free
Got Turbo Inside
Vr struts would be suited to the heavy engine, not sure how well that would match to the mk2
If you've got a VR6 to pinch parts off then grab the rear sway bar for your MK2 as well.
VR6 shocks will be stiff but should be OK if you like a hard ride.
Totally agree on the sway bar
Alba European
Does the upgrade require just the rear bar or the complete axle? If its the compete axle, is it gonna drive weird with wider track at the rears?
I also read we could shorten the front anti roll bar from vr6 and use it on mk2 standard track width. Has anyone done that before?
Maybe I should go wide track for fronts if I can get the subframe...
Got Turbo Inside
Depends mainly on the engine (to the OP). I am running mk3 VR cup kit springs in the front of the MK1 cabby, because the 1.9TD is a heavy lump. I am also running bilstein yellows in the front (the proper bilsteins) which gives it just enough damping.
You really want to match the spring/shock combo to the axle load.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
VR6 sway bar goes straight on to the MK2 rear axle assembly.
