What wheels/tyres are you running?
I have cheap coilovers and they are mega stiff with the 195/50/15's that I'm running. Every bump in the road shakes the car. With 185/60/14 they are fantastic.
I am planning to fit a set of vr6 shocks with mk2 eibach lowering springs, is it going to be too stiff? Anyone tried it before?
Sent from my iPhone using Tapatalk - now Free
Got Turbo Inside
Vr struts would be suited to the heavy engine, not sure how well that would match to the mk2
If you've got a VR6 to pinch parts off then grab the rear sway bar for your MK2 as well.
VR6 shocks will be stiff but should be OK if you like a hard ride.
Totally agree on the sway bar![]()
Alba European
Does the upgrade require just the rear bar or the complete axle? If its the compete axle, is it gonna drive weird with wider track at the rears?
I also read we could shorten the front anti roll bar from vr6 and use it on mk2 standard track width. Has anyone done that before?
Maybe I should go wide track for fronts if I can get the subframe...
Got Turbo Inside
Depends mainly on the engine (to the OP). I am running mk3 VR cup kit springs in the front of the MK1 cabby, because the 1.9TD is a heavy lump. I am also running bilstein yellows in the front (the proper bilsteins) which gives it just enough damping.
You really want to match the spring/shock combo to the axle load.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
VR6 sway bar goes straight on to the MK2 rear axle assembly.
