If you use a spacer, you only lower the compression further - why would he do thisOriginally Posted by finemk1
In terms of pistons, we like to use Mahle or JE; both will make any specification. 11.5:1 is the best street compression ratio for a mild tune 16v. It is both safe and provides a decent boost in mid range. It is possible to go right up to 13.5:1, but this requires modification to the block to set the head at an angle for valve clearance. Remember that the motor will run hotter if bored to 1.9 with higher compression: of course the compression boost creates more heat but there is also less space in the cylinder walls for this heat to be stored. A remote oil cooler is a good idea.
