Results 1 to 10 of 14
Thread: mk3 bottom end for a mk1
    sydney
    is there anything i need to know when getting a 2l bottom end from a mk3 for my mk1 to be maited up to a 16v head, are they all interchangable
    Golfwise Guest
    Lots to know really.
    Need 16v pistons
    Block is taller for a start and generally the inlet manifold / throttle body won't allow the bonnet to close properly.
    It would be interesting to know if there would be enough material on the top of the pistons to machine the clearance needed for the valves ????
    Anything is possible as the head will mate up basically.
    sydney
    so the mk3 is a tall block is it
    Golfwise Guest
    Yes
    VanKronenburg Guest
    What you need to know if putting 16v head on the 8v block is that the compression ratio will drop to 8.2:1 Excellent if you want to turbo or supercharge but hardly that special if you are leaving it normally aspirated
    The tall block 16v will fit, but it is very tight - especially with K-jet throttle body. You need hard engine mounts otherwise the engine will rock back and hit the throttle body on one of the bonnet braces.
    VanKronenburg Guest
    Why don't you fit a complete 16v engine... I don't really understand why you want to do this?
    The only people to perform this are the yanks with their ABA 8v crossflow motor. They build an "ABF" 16v by using the tall ABA block with ABF pistons, head and so on. I don't know why you would do this either as I know you have the ABF in Australia.
    sydney
    i want to run a 2l 16v on dellortos if it get to hard to run the bottom end i will run a 1.8 but i am looking to make this one nice and old school fast, so clearance shouldnt be an issue as the head will be manifoldless in the traditional scence
    VanKronenburg Guest
    Quote Originally Posted by dubstarmk2
    There is no difference in difficulty to run a 1.8 or 2.0 block - the point is that if you fit a 16v head to an 8v block, you will be building a low compression motor.
    There are still clearance issues with throttle bodies or twin carbs in a Golf 1 with certain DCOE manifolds and a tall block 16v. Some of the long port manifolds reach out so far that the airbox or filter socks you need to run will touch the front of the bonnet.
    If using a tall motor, you'll need one of the shorter port manifolds, like a Dbilas Tuning one. If you need contacts for these parts, send me a message.
    Also, with the carb setup, you will not gain much power or torque with the standard cams. Twin 45s are great with a ported head and mild cams and will get an honest 180ps - not like the UK cars we all read about with stock 16v and 190hp :roll: Rubbish. :!:
    sydney
    so boring a 1.8 bottom end sounds like the go and the head will be having work done aswell
    VanKronenburg Guest
    Yes the 1.8 16v bottom end would be the best choice. Bored to 1.9 they are better than the 2.0 if you are building a normal aspiration motor - they rev better mainly. The 2.0 head is best to use to modify if the machinist has little experience as there is more material to work with. All the heads produce very similar results if they are well modified, though.
Similar Threads
  1. Bottom Skirt Clips for Mk1
    By barrygti in forum Mk1 Golf
    Last Post: 04-03-2007, 04:19 PM
  2. Aaaaarggghhh!!
    By mollins in forum Mk1 Golf
    Last Post: 25-02-2007, 08:33 PM
  3. Bottom End rebuild Advice
    By smithy010 in forum Mk1 Golf
    Last Post: 28-10-2006, 11:13 AM
  4. Torque setting for bottom end
    By 82cab in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 10-11-2005, 09:55 AM
